Traffic Simulation Error in Infraworks 2020
Hi everyone,
I try to carry out traffic simulation in InfraWorks 2020 , but the attached message always appear
I installed JRE from the mentioned link but the same message appear
How Can i solve that ?
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
I can see two possible reasons:
  1. The Java Runtime is not installed correctly or incomaptible
  2. You are running an InfraWorks version that is not supported anymore with Traffic Analysis
Karsten
Karsten Saenger
I launched Infraworks 2020.2 from the attached window .. but the same message appear
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
which of the following mentioned JRE runtimes did you install?
Java Requirements for Autodesk InfraWorks
Personally, I can confirm that "Amazon Corretto 8" works on my system.
Karsten.
Karsten Saenger
