TIP: Create Custom Properties in Infraworks 360
Matt__W
Advisor Advisor
Message 1 of 13
Matt__W
This is a follow up to an article I posted the other day.
With a custom im.schema.json file you can create additional attributes for Infraworks 360 which will allow you to increase the data-richness of your model and expand the possibilities of thematic displays and the way you present the information within your model.
Link to Autodesk Knowledge Network article.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Replies (12)
Message 2 of 13
Willy_Campbell
Well done @Matt__W! I wonder if this could be used for extended data in pipes/structures as well?
Willy Campbell
Message 3 of 13
Matt__W
What do you mean extended data? What specifically are you thinking about?
Matt Wunch
Twitter | LinkedIn
Message 4 of 13
Matt__W
Almost forgot.... Thanks!!
Matt Wunch
Twitter | LinkedIn
Message 5 of 13
Guys!! This is super amazing! We are changing the world of instrastructure 😃
I truly hope Infraworks will become more and more (let's say) "parametric" and "open". I'll post the Idea in the other forum!
Have a great day!!
Nick
Message 6 of 13
Matt__W
@Willy_Campbell, one thing I just noticed is that the properties of a structure that's part of a drainage network (from the DESIGN DRAINAGE toolbar) are all grayed out and disabled while the properties of a stand-alone structure (from the CREATE CONCEPTUAL DESIGN FEATURES) aren't.
Matt Wunch
Twitter | LinkedIn
Message 7 of 13
JasonArtley
Impressive work Matt! Thanks for sharing!
Message 8 of 13
Matt__W
Thanks.
And you're welcome!  🙂
Matt Wunch
Twitter | LinkedIn
Message 9 of 13
This works great thanks!
Is there a way to delete custom properties categories?
I wanted to rename some custom properties and the old names remain under UNKNOWN CATEGORY.
Message 10 of 13
wanpichk
Hello , I want How to create and custom Property value. You can help me?
wanpichk@gmail.com
Thankyou
Message 11 of 13
Karsten.Saenger
Autodesk Support
Autodesk Support
Message 12 of 13
h.malgarezi
Where can I download the sample file schema.json indicated in the article above?
The provided link is not working
http://a360.co/2cqMvb0
Message 13 of 13
Matt__W
I'm not sure what happened to the file but here's a link to a new one.
http://autode.sk/2nIDJZq
Let me know if you have any issues with it.
Matt Wunch
Twitter | LinkedIn
