Show station in cross section view: Can't turn on Surface Layers
tcorey
Mentor Mentor
tcorey
When I use the Show station in cross section view function, it won't let me click the button next to Surface Layers.
All surface components are turned on. The terrain is present in the model. I have tested in three different models, all with the same problem.
Any ideas?
Version 21.0.26.0
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @tcorey ,
I can confirm that the surface layer doesn't seem to work in the cross section view on my side as well. Let me investigate, I will come back to you with news.
Karsten.
Karsten Saenger
samir_rezk
Hi @tcorey
I see the Surface layers in my test! can you confirm that your Surface Layers are in different surface categories?!
Hope this helps,
Samir Rezk
Technical Support Specialist
tcorey
Thanks @samir_rezk In the lower right corner of your image, I found the answer. Surfaces won't display in Assembly View.
Tim Corey
Redding, CA
