InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Rotate all objects using data source
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
Karadzhaian_Eduard
913 Aufrufe, 8 Antworten
Hi all,
I want to add design lightpoles to my Infraworks model.
As an existing source data i use AutoCAD blocks, either of them have an individual rotation angle.
I try to import this data using GIS format (.sdf) - data completely have been added to Infraworks with standart rotation angle for all objects.
Next I want to automatically rotate all data objects using script:
But it doesn't work.
I'll be glad to get any advices ASAP.
Thanks in advance
Eduard Karadzhaian
Senior Civil Infrastructure Engineer
Blog| LinkedIn| E-mail| Youtube|
8 ANTWORTEN 8
Nachricht 2 von 9
@Karadzhaian_Eduard
If your SDF has a a rotation attribute on it, you can map that to the 'rotate z' field in the table view at import. No script required.
AEC Collection / Safe FME / ESRI ArcGIS / Unreal Engine
Digital Engineering Lead, Compulsive Problem Solver.
Nachricht 3 von 9
@andrewofabley could you please confirm this information using screenshot?
In 'rotate z' field it is impossible to input rotation attribute name or choose it from list. There is a possiblity to input only absolute values. Essentialy I have rotation attribute in my .sdf file.
Eduard Karadzhaian
Nachricht 4 von 9
Another situation with "Set elevation" value. Here there is a possibility to adjust any attributes values.
Eduard Karadzhaian
Nachricht 5 von 9
My problem solved.
Really script was so easy:
function Process(SOURCE, CITY_FURNITURE) {
CITY_FURNITURE.MODEL_ROTATE_Z = SOURCE["ATTRIBUTE_NAME"]*180/3.14;
return true;
Eduard Karadzhaian
Nachricht 6 von 9
Hi @Karadzhaian_Eduard ,
just for answering the open question about where to define the rotation - if you have an attribiute in the SDF/SHP files for rotation, you can select it in the table tab:
Karsten.
Karsten Saenger
Nachricht 7 von 9
How to export object in Civil 3D with attributes, I use command MAPEXPORT but it no attributes, please help!
Nachricht 8 von 9
mark.reeveTXANL
als Antwort auf: inception2708
I try the above method and am still not getting the same rotation as in CAD. I have an SDF with extracted rotation values, I map that attribute (and convert from radians) but it is still a different rotation to the CAD. The value is the same but the angle is different.
Nachricht 9 von 9
namlt33
Go to data tab, select "select attributes" chose the properties you want
Rail Community
