Is there a possibility to reorder grading areas, so that they stack in right order?
Regards
Egil
Regards
Egil
Hi @egil.rasmussen,
I believe reordering grading areas doesn't work with sketched grading. These are all gathered in the "Sketched" layer.
If you imported data sources as grading areas, there is a possibility to order them.
A possible workflow to get the sketched grading areas as separate data sources (i.e. Shape files) to import:
Karsten.
