printing
printing
rmkaack-jvb
Message 1 of 9
printing
rmkaack-jvb
is there a way to print a hard copy of a terrain theme or export it so it can be inserted into civil 3d and then printed.
i need this for a client.
thanks
Replies (8)
Message 2 of 9
Matt__W
You could print a SNAPSHOT of the model with the terrain theme set which you could then bring into Civil 3D.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 3 of 9
Eduardo.Soethe
Hi @rmkaack-jvb
You can do it in Civil 3D.
Try to read this article for help you!
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/...
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
Message 4 of 9
JasonArtley
You could use the snapshot command to create the image, then insert that into Civil3D or other software to send to the printer. You could also use Windows Snipping Tool to grab a screenshot of the theme legend.
Message 5 of 9
Matt__W
So @Eduardo.Soethe's reply brings up a good question... WHICH application has the most current surface? Did you create some rough surface in IW using some of the grading tools (land areas, roadside grading) or does C3D have the most current surface?
Either way, you've got a few options/solutions to work with.
Matt Wunch
Twitter | LinkedIn
Message 6 of 9
Hey @Matt__W and @Eduardo.Soethe,
I agree and I am eager to find out which one has the most current.
What do you use?
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
Message 7 of 9
rmkaack-jvb
after some playing around i figured out how to theme the terrain using the display manager in the planning and analysis workplace.
how do i tweak the color variations and also how do you insert the legend so it will print.
Message 8 of 9
Here you are @rmkaack-jvb,
https://knowledge.autodesk.com/support/infraworks-360/learn-explore/caas/CloudHelp/cloudhelp/ENU/Inf...
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Message 9 of 9
Carrillof
You can take a picture with a Snapshot, the other option is to take the surface to civil 3d and create a surface analysis (slope, elevation, runoff, etc.) or if it is something more detailed with the tools of planning and analysis create thematic map .
