Parametric Revit Family example for girder ?
Agence_LC
Agence_LC
Is there somewhere a parametric RFA file example wich could illustrate how we make a parametric grider for bridges in Infraworks ??
We are somehow in the dark to understand what kind of file we need and wich are the mandatory parameters ?
2D ou 3D file ? Can a 2D profile be lofted along IW alignements ? Where is the origin ? Do we model on the XY plan or YZ ? ..and so on...
We really need an in depth tutorial and reference handbook to master this parametric conception
regards,
Chris
lim.wendy
Hi Chris,
Thank you for reaching out with your questions.
I recommend checking out the article at the following link: Using Revit Family for InfraWorks Parametric Component. It provides insights and examples and should provide some guidance. However, if you need further assistance or have additional questions, please don't hesitate to ask.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Agence_LC
I can't find in the documentation the list of parameters to use to design parametric girders with Revit. It's very confusing, speaking only about drainage.
AboutAuthoringInfrastructureContent_ParametersReference
The simplest thing would be a sketch showing which variables are expected by Infraworks and how to implement them in a Revit family.
Could someone post a simple example of a Revit parametric girders?
thank you very much.
