Model positioning
Model positioning
Message 1 of 10
Model positioning
Hi!
A problem bothers me every time when I create model. Because of the blue background in infraworks 360, the model looks at near by water. The only solution I came out is to input a large terrain model and satellite photos which costs more running time. Is there settings I can change to avoid this situation?
Thanks in advance.
Replies (9)
Message 2 of 10
Matt__W
Hi, @Anonymous. You can give this a try. Make sure you back up any files beforehand, just in case. I'm not sure if it'll work with the latest release or not though. The AKN article only lists InfraWorks 2015 & 2016.
https://knowledge.autodesk.com/support/infraworks/troubleshooting/caas/sfdcarticles/sfdcarticles/Changing-the-background-color-in-InfraWorks-using-GIMP.html
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 3 of 10
elliott.rosenfeld
Hi Jingyj,
You can easily switch your view from Conceptual View to Engineering View using the Utility Bar, which will change the sky background color and give you more of an engineering view for detailed design. engineeringview.jpg
You can read about how to do this here: http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-4E69D369-5282-46FF-B4AE-62BBB8A2E964
Elliott
Principal Specialist, Infrastructure
Message 4 of 10
Thank you. It works!
I changed the background colour to white, and it seems brown-gray in effect.
Message 5 of 10
Thanks! That is a great new feature! But unfortunately I have a old version 2016.
Message 6 of 10
elliott.rosenfeld
You may be able to use Javascript to turn off the dynamic sky in InfraWorks 2016. Here's an article explaining how to do so: http://autodesk.typepad.com/bimagination/2015/10/in-infraworks-2014-there-were-many-options-to-contr...
Elliott
Message 7 of 10
triszeng
How did you do it work? @Anonymous
thank youSmiley Sad
Message 8 of 10
try infraworks 2018. haha
Message 9 of 10
triszeng
i already in infraworks 2018. But i can not find any option to change the background color.
I know "engineering view".
Message 10 of 10
Hi, Does it work not well in "engineering view"? I don't have the new version so not sure about that.
I tried the solution I got from the first answer. It's about changing a color file in Instraworks system document. And it works well for me.
