Hi I used Navisworks to import a model (Original [mm] dwg in RD-new) , exported it as FBX. This seems a workaround to help IW. But somehow it does not show onto the map. Any advice?
Hi @Anonymous,
try to use XY-MM as coordinate system in InfraWorks and select "interactive placement".
Does the model show up now?
If yes, the scaling might be wrong when you use CS "RD" on a millimeter DWG.
Karsten
