model builder and distance
Message 1 of 12
Hello
the model builder is very bad he have old image and elevation in not accuracy at all plus i think u don't have tools to measure the distance but it's really a very good program but need sum fix
best regard
Replies (11)
Message 2 of 12
Tomislav.Golubovic
Model Builder uses Bing Maps to start off with. If you want more updated images you can use your own.
Message 3 of 12
oky thank you for your'e time
Message 4 of 12
but what about the distance tools whys is not exist ?
Message 5 of 12
ramesh_sridharan
@Anonymous Doesn't the point-to-point distance tool help?
Ramesh S
Product Manager - Infrastructure Solutions
Ramesh.Sridharan@autodesk.com
Ramesh Sridharan
Product Manager
Message 6 of 12
Hello
what is point to point can you insert image
best regard
Message 7 of 12
ramesh_sridharan
@Anonymous Can you please check the attachment in my previous message?
Ramesh S
Ramesh Sridharan
Product Manager
Message 8 of 12
thank you i find i have another question for you why when i convert to component road all the object go to the middle do you have any idea
look here
thank you very much for your time
Message 9 of 12
SethHall
Hi @Anonymous
The reason some objects shift during conversion depends on the construction of the original style road and the attachment points of those objects. Also some tracks of the original style map differently to the new road components. For more information on this please see this help article.
I would recommend examining the original style and see if any of these discrepancies apply in this case. Hope this helps!
Seth Hall
Product Owner
Model Builder
Message 10 of 12
Hello
        thank you for your'e time i read the article and i see that no solution for this problem because when i convert to component road many feature will be add and make all that difference        best regard
Message 11 of 12
 hello finally i find the solution by change track offset not y translation i apply the change for the red car only and that happen
all object go to the middle except the red car because i edit from track offset not y translation
Message 12 of 12
SethHall
Glad to hear it!
Seth Hall
Product Owner
Model Builder
