Hello:
I am attempting to select a parametric Bridge Deck component within InfraWorks 2022 however it does not appear in the Select Component dialog box. The deck component has been loaded into InfraWorks and appears in the Style Palette > Parametric Models > Bridge > Decks. The component is one that I authored in Inventor and exported accordingly for use in InfraWorks. As a test I also copied one of the deck templates included with InfraWorks, renamed it, opened it in Inventor and exported it out as an Infrastructure Template, loaded it into InfraWorks, and it does not appear in the Select Component dialog box either. I have not had this issue with piers or abutments. I have tried this on several different InfraWorks models.
Has anyone had success creating a custom deck template, any ideas of where I may be going wrong?
Thanks;
Nick
