Integrating AutoCAD Map 3D and Autodesk Infraworks 360 with PostgreSQL and PostG
alexlibrelon
alexlibrelon
Many have heard of it and have even seen in its Civil 3D, AutoCAD Map 3D, Infraworks 360 and others tools to connect an external Database.
This video addresses you clearly and objectively, how to publish your tables in the database and access it with AutoCAD Map 3D and Autodesk Infraworks 360, making the information interactive.
Dataset (Shapefile)
http://a360.co/2fcT2V4
Alex Librelon
Projetista Master - Youtube | Blog | Linkedin
- Marque a resposta que resolveu o seu problema como solução, isso ajuda os outros usuários em suas buscas;
- Clique em "Curtir" caso a resposta tenha ajudado;
scunningham
Thanks for sharing this.
Sarah Cunningham
Product Manager, Autodesk Takeoff
