Installation problem infraworks 2017
Message 1 of 8
I am a Revit user. I've just installated Autodedesk Building Suite Ultimate but I can't download Infraworks 360 LT even if it's included in my Suite. In my screen (showed below) I can click on "access now" but the link is for the next link:
https://knowledge.autodesk.com/support/infraworks-360/troubleshooting/caas/sfdcarticles/sfdcarticles...
Replies (7)
Message 2 of 8
Eduardo.Soethe
Hi @Anonymous Can you contact your seller or support?
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
Message 3 of 8
Yes, I contacted him but he said to try to ask here 😕
Message 4 of 8
Matt__W
@Anonymous... On this page it states: "Note: All maintenance plan benefits may not be available for all products in all languages and/or geographies. Maintenance plan is subject to the maintenance plan terms and conditions." Maybe you don't have access to it??!? I also have the Ultimate Suite and when I click on IWLT it brings me to the same page. But I also have the full version as well.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 5 of 8
Thanks Matt,
so do you have any suggestions or I've just to wait for updates??
Message 6 of 8
Matt__W
Not sure. I'm located in the United States and according to this link it's not available in my country??
Hopefully someone from the Autodesk group can shed some light on this.
Matt Wunch
Twitter | LinkedIn
Message 7 of 8
Matt__W
In the meantime, contact your reseller. Maybe they can point you in the right direction.
Matt Wunch
Twitter | LinkedIn
Message 8 of 8
Thank you, I'll do it now.
