Hi All
i need to import my project site (contour) which updated from real site to infraworks to work on it, is there any method i have a 3d cad dxf file.
thanks alot
@BushW has edited your subject line for clarity: How to import 3d dxf file contour model inside infraworks??
Solved by kindchk1. Go to Solution.
Solved by BushW. Go to Solution.
Hello @arch_moataz
I'm not familiar with Real site software but, here are AKN articles on To import 3D models and Supported File-Based Data Formats along with a
the video Importing a 3D Model to help with importing data to Infraworks.
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank you for doing so, and I'm here to help.
You can make a contour in a way that Infraworks itself has a function for its own :
I hope this helps!
Or
If you like to just use the specific contour line for the terrain surface, try to use the method of this video :
Hi @arch_moataz
I'm just checking in again to see if you need more help with this. Did the suggestion I provided work yesterday for you?
If so, please click ‘Accept as Solution’ so, that others can more easily benefit from the information and thank you for doing so.
