I've recently started using Infraworks for Bridge design and first thing that I learned is that it takes more than Infraworks to get your design as accurate as possible. Depending on complexity of design you need to use Civil 3D, Revit and Inventor. Next thing I learned is that all those apps need to be in the same version, for example Infraworks 2018, Civil 3D 2018, Revit 2018 and Inventor 2018. Third thing that I've learned is that if you plan to use Inventor to create your own elements for Infraworks you need to INSTALL INVENTOR FIRST (lot of people had that problem) otherwise you won't be able to export element from Inventor and use them in Infraworks. There's many more other things that you start discovering once you get into more often use of Infraworks but that's for another discussion.
My question is will that be the standard practice in future? Do I need to update Inventor first, then Civil, then Revit and then Infraworks so that everything works properly?
Thank you,
Regards
