I been using the fbx exporter from infraworks previous versions and it works flawlessly. I recently tried exporting from the 2020 version with the .2 update and the aerial stitching does not align properly when exporting as an fbx. I was able to reproduce this issue in many different areas, and with different pcs. Both computers are running Windows and one has a 1060 GPU and other one a 3060, both have more than 16GB of ram.
The model still looks good inside infraworks even after exporting, its just the fbx that its corrupted. Hopefully someone can help with this issue! Let me know if more info is needed.
Thanks!
Hugo H.
Thanks!
Hugo H.
Solved by hhernandez6J6A9. Go to Solution.
Solved by ramesh_sridharan. Go to Solution.
@hhernandez6J6A9 This sounds odd. Would it be possible for you to share your model for us to check it out? Please email me at ramesh.sridharan@autodesk.com if you need a place to upload. Thanks,
Hi Ramesh,
I found the issue. The fbx created by infraworks is not compatible with the Windows default viewer, I opened the model in Blender and the aerial lines up like it should.
Thanks!
Hugo H.
Hi Ramesh,
Thanks!
Hugo H.
