Infraworks 2019 doesnt start and also shows no error screen
nkg2
Message 1 of 32
nkg2
Good afternoon.  I am experiencing the same situation where Infraworks will not startup and no error screens.  I will see flash of another window but then closes.  It is not on under task manager details as well.  I have uninstalled and reinstalled.  I have tried opening it with and without the hotfixes.  I am the primary user and can get into other autodesk products without issue.  Please advise.
@nkg2
Reply has been made a very own topic and the title adjusted accordingly by Tarek_K
***Viewer/Reader Discretion is Advised***
Autodesk 2025- Architectural, Engineering and Construction Subscription & Infraworks
Windows 11 Professional, x64, Microsoft Surface Studio 2
Replies (31)
Message 2 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @nkg2,
the issue in the above case is that the AdSSO.exe process does not start on the computer.
The AdSSO stands for Autodesk Single Sign On and it's responsible for checking for and getting license information. If it's not started, InfraWorks cannot get access to any license information - even the info if a license is available at all and will possibly just started in viewer mode - and shuts down.
The above case is still under investigation by the development team and there is no solutioin (yet).
What Windows version are you working with, Windows 10, 7 or 8?
Karsten.
Karsten Saenger
Message 3 of 32
nkg2
Thank you for the quick reply.  Windows 10, 64-bit
Message 4 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @nkg2
thanks for the info.
You can check if you also have the same issue with AdSSO by starting the service manually from C:\Program Files\Autodesk\Autodesk AdSSO\AdSSO.exe
The open the Task Manager -> Details Tab, is it listed there?
Karsten
Karsten Saenger
Message 5 of 32
nkg2
@Karsten.SaengerInteresting.  I do not have that folder at all in either Program Files or Program Files (x86).
Message 6 of 32
nkg2
@Karsten.Saenger  So if I don't have this on my computer and I have uninstalled it and reinstalled it from the web, how come the folder is not there or the file itself?  My other programs seem to be working.  Is this file/folder limited to Infraworks?  Regardless, where can I get that file folder and file in question?  Thanks!
Message 7 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
@nkg2 - that is strange.
Can you check if you can install it from the InfraWorks installation files from folder Autodesk InfraWorks\3rdParty\x64\AdSSO ?
When it's missing, did InfraWorks ever start correctly before or do you try to start after a first time installation? How did you install InfraWorks?
Karsten.
Karsten Saenger
Message 8 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
@nkg2 - please
  • uninstall InfraWorks again
  • go to your Autodesk Account page (accounts.autodesk.com) and "browser download" the InfraWorks installation package
  • install locally
Let me know if that worked for you.
Karsten.
Karsten Saenger
Message 9 of 32
nkg2
@Karsten.Saenger  No it did not work.  I did not even apply hotfixes yet either.  I am not seeing the file either even after this install.  I'm debating whether or not it did work after I removed 2018 last month and installed 2019.
Message 10 of 32
nkg2
@Karsten.SaengerTo update you on what I have done so far, without success, here is what I have done:
  • I have a home license and checked to see if 2019 would work on that machine.  It is working fine.
  • I went to my home computer C:\Program Files\Autodesk\ to see if the folder ADSSO was there and it was.  So I copied the contents of that folder and brought it to work.
  • I placed the folder and contents over to my work machine and had to start adsso.exe manually.  Confirmed it was in the details portion of task manager
  • I tried opening Infraworks and it is not working.
  • I repaired Infraworks and with ADSSO running it still did not work.
Message 11 of 32
nkg2
@Karsten.Saenger
I have included a screencast of my infraworks screen to show you what is going on.
Message 12 of 32
nkg2
Message 13 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @nkg2,
thanks for testing, it looks like it's the same issue as above, but I am not 100% sure yet.
It's good to hear that InfraWorks works fine from you home computer.
Could you please send the latest InfraWorks log files from C:\Users\<<USER>>\AppData\Roaming\Autodesk\Autodesk InfraWorks\logs   ?
Karsten.
Karsten Saenger
Message 14 of 32
nkg2
My Infraworks folder is empty.  No logs.
Message 15 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @nkg2
ok, everything sounds like an installation issue of InfraWorks.
I think the best next step is to create a support case and assign it to the installation support team so that they can take a look.
I will create that support case for you.
Karsten.
Karsten Saenger
Message 16 of 32
nkg2
@Karsten.Saenger
Thank you very much!  If you could set the priority not at the highest but at a level below it I would appreciate it.
-NKG
Message 17 of 32
nkg2
Just to provide an update on my situation:
After working with Autodesk support staff, my problem was finally resolved after complete clean uninstall (combination of uninstall tool and microsoft uninstall tool) plus deleting some FLEX files.  That was the last resort and it finally worked.  There was nothing to point a finger at.  My suggestion after working with all of this to do a clean uninstall of all autodesk products via the following link:  https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
Then install Infraworks first to ensure that it will work before proceeding with adding the other software back in.
Message 18 of 32
Not working for me either:
ServiceFoundation.cpp(399): error: Restoration of login failed
I'm using Infraworks from two machines, on my home desktop (IW2018) it functions perfectly, on my work laptop it won't open (IW2019). Same antivirus and firewall on both machines.
Message 19 of 32
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous,
sounds like a different issue.
Do you have log files available. Usually, at home you have an open network and at work it's much more restricted, for example with proxy server or additional Firewall on the company network.
Karsten.
Karsten Saenger
Message 20 of 32
JamesMaeding
@nkg2
Are you kidding me "do a clean uninstall of all autodesk products" just to get IW working???
Autodesk should be completely embarrassed by this. They simultaneously hide the version of IW from users, then expect updates done via Desktop App, which only works if you have admin rights, then there are problems anyway with new versions. Its a living car crash.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
