Greetings, I had a problem with INFRAWORK 360 ...
I was working on a model, I click on the view cube, to change my view, and the whole Infrawork screen is dark or black color, I do not even the view cube, like to switch to another view .. .
After several attempts I have no result, so I click the option to REGENERATE, and I return to recover the view of my model, but with the surprise that the sky is no longer seen, but there is a background Dark, keep trying and I could not solve ...
Close the program and I reopened it and did not solve anything, restart my pc and without any result, close the program and leave it for the next day, I opened the model the next day and I still have the same problem ...
I think that maybe it was problem of my model, so I opened another one and with the same problem, I even opened a model that comes by default with the Infrawork and still with the same problem ...
Then I thought I needed to update, so I update the Infrawork to version 17.3.133.0 and I still have the same problem, I do not know what could be, I would appreciate your comments and solve this problem and get the sky back as a background. The models, I leave a reference img:
Thank you very much for the help and I clarify that before I did not have this inconvenience ...
Atte.
ESPAÑOL
INFRAWORK CON FONDO OSCURO
Saludos cordiales, se me presento un problema con INFRAWORK 360...
Estaba trabajando en un modelo, doy clic en el cubo de vista, para cambiar de vista, y toda la pantalla de Infrawork se pone de color oscuro o negro, que incluso no se el cubo de vista, como para cambiar a otra vista...
Después de varios intentos no tengo resultado, así que doy clic a la opción de REGENERAR O REANUDAR, y vuevo a recuperar la vista de mi modelo, pero con la sorpresa de que ya no se ve como fondo el cielo, sino que hay un fondo oscuro, seguí intentando y no pude solucionar...
Cerre el programa y lo volvi a abrir y no resolvió nada, reinicie mi pc y sin ningún resultado, cerré el programa y lo deje para el dia siguiente, Abri el modelo al día siguiente y todavia sigo con el mismo problem...
Pense que talves fuera problema de mi modelo, así abrí otro y con el mismo problema, incluso abri un modelo que viene por defecto con el Infrawork y todavía con el mismo problema...
Después pense que necesitaba actualizar, así que actualice el Infrawork a la versión 17.3.133.0 y sigo con el mismo problema, ya no se que podría ser, agradecería mucho sus comentario y poder resolver este problema y poder obtener de nuevo el cielo como fondo de los modelos, dejo una img de referencia:
Muchas gracias por la ayuda y aclaro que antes no tenia este inconveniente...
Atte.
PD:
Si la info es de tu interés, dale manitos arriba (KUDO)...
Si la info da solución a tu inquietud, o es conocimiento nuevo para poderlo aplicar en el futuro, acéptalo como SOLUCIÓN...
TU ACEPTACIÓN O APOYO EN CUALQUIERA DE LAS 2 FORMAS, ES EL INCENTIVO PARA PODER SEGUIR APORTANDO CON LO MUCHO O POCO QUE SEPAMOS DE ESTE GRAN SOFTWARE PARA EL BIEN DE TODA LA COMUNIDAD...
Felices festividades de Carnaval y feriado...
ALEJANDRO PANCHANA (Guayaquil-Ecuador)
Facebook | Twitter | Screencast
Solved by Matt__W. Go to Solution.
Solved by roskirko. Go to Solution.
@ajpancha The first thing that comes to mind is... is the graphics card driver up to date??
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Is it just one model or ALL models?
Matt Wunch
Twitter | LinkedIn
PD:
This same thing happened to me and furthermore I got a
."Data Import Warning"
Could not load protein materials successfully. You may not have the correct Autodesk Material library installed. The Material Library required is packeaged with an installation of Revit, 3DS Max or some Suites of the same year as your Infraworks 360.
So, I just upgraded my Infraworks and it says 2017.3 and I am only using 2016 releases. My infraworks screen looked exactly like yours after I did the upgrade.
Try to load that .fbx into a new project and see if you get this warning I did.
Now I would say I have to install 2017 which our company does not use to maybe fix this. HMMM, seems like a big problem coming for this 360 software..............
You are in the "Engineering View", which is dark by default.
Try switching to the "Conceptual View" (near the top middle of the AIW screen).
@roskirko Awesome catch! It's always the simple things, ain't it? <side note> I didn't realize that setting "stuck" between models. It does! </side note>
@ajpancha Here's how you can toggle between Conceptual and Engineering views.
Matt Wunch
Twitter | LinkedIn
PD:
No need to apologize. We've all been there at one point, overlooking something so simple. I'm just glad you didn't have to reinstall. 🙂
Matt Wunch
Twitter | LinkedIn
