Infrawork logo instead of manhole in drainage design over roads.
Infra work logo instead of manhole in drainage design over roads. Is this a technical glitch ?Infrawork logo instead of manhole in drainage design over roads.Infrawork logo instead of manhole in drainage design over roads. ?
Charlie.Ogden
That usually means there's a problem with the Inventor Server component rendering the part - either the Inventor templates can't be found or maybe if the part was built with a newer version of Inventor or Parts Editor (but that would only be the case if you are not using the latest InfraWorks). Does this happen with all parts or just some of the parts? Are they custom parts? What version(s) of software are you using?
Charlie Ogden, PE
Product Manager
 Dear Charlie,
Kindly find below reply for your quires.
Inventor Server component rendering the part - either the Inventor templates can't be found or maybe if the part was built with a newer version of Inventor or Parts Editor (but that would only be the case if you are not using the latest InfraWorks)- I HAVE UPDATED LATEST VERSION RECENTLY, ONLY UPDATE WHICH I DIDN'T INSTALL WAS INFRASTRUCTURE PARTS EDITOR 2019  ( ATTACHED DETAILS OF AUTODESK DESKTOP APP).
Does this happen with all parts or just some of the parts? - ONLY AT SOME OF THE PARTS.
Are they custom parts?  - NO, IT WAS OUTCOME OF INFRAWORKS ANALYSIS.
What version(s) of software are you using? - LATEST VERSION ( ATTACHED DETAILS OF AUTODESK DESKTOP APP).
