Import Camera Path (road alignment + profile shapefile)
Tsepang.RanneilengNSMJ2
Hi all,
I am trying to create a storyboard for a road corridor in InfraWorks 2025. I have imported the corridor as a civil 3D model. When creating the storyboard, I selected "Import Camera Path" (as the road was not created in Infraworks and cannot be selected as a component road) and tried to import the road alignment + profile as a shapefile. However, I get the following error message: "Keyframe data could not be read using the current configuration."
Has anyone come across this before and can assist?
Sean_Fahey_10
I have not run across that error.  Can you explain a little more about where your roadway is coming from (or show picture of Data Sources)?  Because if its coming from Civil 3D you should be able to have it come in as a component road.
