please. I don't know how to get ground imagery to my model in infrawork 360 2017 , if any one tell me what is the completely procedure to do so it would be amazing thanks
Solved by Alfred.NESWADBA. Go to Solution.
By default ... drag and drop it from Windows Explorer to your Infraworks scene. Don't forget the dialog for configuration (especially to set the coordinate system which is not always know for aerial images).
- alfred -
how can I get the images , is there any website can provide me with such pictures
It depends where your project area is (on the world)!
You might look to the homepage of the local government gis department.
...or you chose Infraworks 360 Model Builder to start your project, it will import surface, aerial imaginary, streets and buildings from open source dataservers, afterwards you can change to your local data if you have any (mostly then with higher quality.
>>>more details about Model Builder<<<
- alfred -
