Announcements
How to Hide Terrain in a Long and Complex Corridor.
jcasadoTMEC5
jcasadoTMEC5
Hi Everybody, I need to hide all the areas where I have the corridor, I know that I can use Terrain Hole Coverage, but is a long Corridor with a complex shape and doing it manual I could be a long process.  What kind of tools do you use to solve this problem.? Thank you.
ToddRogers-WPM
So, what you want to do is change the order of your surfaces. To do this, you go to the Manage tab, and click on Surface Layers. In that dialog box, you can grab your surface and move it to the top. Alternatively, you can turn other surfaces off in this same dialog box. The order option is probably your better option.
Todd Rogers
jcasadoTMEC5
Thanks for your answer, but It doesn't work, because my surface doesn't appear on Surface Layers, I have the same problem with Parcels.
nestorbarreraromero
Hi, what I suggest is export your terrain as IMX to Civil 3D and there try to paste it with your corridor surface  and export back  to InfraWorks
jcasadoTMEC5
Hi Nestor,
Thanks for your quick answer, ok I'll try it . Thank you¡¡
