Announcements
How to create green zones separation on sidewalks?
admeza
admeza
Hi!
I want to create this kind of result on the sides of my streets, with a green zone with threes between the sidewalk and the bikeway, but on the street style palette it creates a single line, without interruption so people can cross.
I tried with the linear decoration tool but the most similiar is this one and I can't change its size. So, do you have any suggestions? Thanks.
ToddRogers-WPM
Download a model from 3D Warehouse and import it. You can then add it to your library and use it as a linear feature.
Todd Rogers
admeza
Thanks for the answer! Can you please tell me how can I add a skp imported model to use it as linear feature?
ToddRogers-WPM
You can use the free online Sketchup to export the .skp file to a .dae (collada) file. Then add it to your Style Palette under the 3D Model tab. Then you can use a linear component using that model.
Todd Rogers
