Geospatial Vector Data (shape file) import troubles
Carla_RohmJM38E
Carla_RohmJM38E
I have a shape file of existing bridges that originates from ARCGis. When importing it to Infraworks, it detects the vector and gives me a range of options on data source configuration (see image). Problem is, I am not really finding anything that works for me. Closes I got was to choose the type as "barrier", but that won't give me an accurate representation, as the barriers have height assignment and I am not sure what the gripping point is given it is a deck with a top and bottom. Any suggestions?
Todd_Rogers
You're only going to get certain options by using a shapefile. Bridges and tunnels work much differently than anything else.
Todd Rogers
Civil Administration at Walter P Moore
Carla_RohmJM38E
I can check with the geospatial guys what other export options they have. What would you recommend?
Todd_Rogers
For an export, you can only export from Revit to have an actual bridge. You will just need to create the bridge from within InfraWorks.
Todd Rogers
