Error Invalid Extents on New Model Define City Extent
IM 2013.
Using coordinate system: RSA-LO29/01
Extents needed (Y over 2 million):
Min … 86690,-2916160
Max … 87790,-2915140
result is .. error: Invalid Extents
The given extent does not intersect the defined boundaries of the model coordinate system! Valid extents must be in the range of [-194843; 0] - [194843; 1.00019e+07]
but...
IM does allow the import of data using these values .. just cant set the City Extent..
The solution for users in RSA is to use the Lo-xx-WGS coordinate system to define the City Extent.
Only use the RSA-LOxx/01 coordinate systems for importing IMX from C3D designs (when the reverse sign method is applied in C3D)
We are also in South Africa and tried this, but the error persists.
It is happening to all of our IW projects based in SA and is proving troublesome.
We eventually managed to get it it export to FBX via one of the "test" coordinate systems, however the scale is very strangely out when taking the FBX into any other programme.
Is there anything else we can try?
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous,
what coordinate system (CS) are you using exactly?
I recently noticed some CS issues with South African CS's, see post https://forums.autodesk.com/t5/infraworks-forum/working-with-infraworks-in-south-africa/td-p/8651592
Karsten.
Karsten Saenger
bim
[...] truncated
Hi Karsten,
We are using the Hartebeeskhoek94 set of coordinates, usually LO29, although all of them through LO19 to LO33 give the same issue.
We are usually accustomed to having to turn maps around as all of our maps import upside down. Thank you for the link, I'll forward it to my team and see if it resolves their issues.
We've been experiencing tons of interoperability issues between IW and Revit because of the CS being upside down, I'm hopeful this will work. Will keep you up-to-date whether this resolves our troubleshooting.
