CLOVERLEAF IN INFRAWORKS, INTERCHANGE PROBLEM
Beka_Tchigladze
Advisor Advisor
Beka_Tchigladze
HELLO
So I want to make some design of cloverleaf made an assembly of road and sweep it on one alignment now I want to add ramps but it does not work properly I want to interchange to connect with one lane and not conflict to others. what should I do to solve the problem. and what should I foresee when making interchanges of roads in Infraworks?
here is a screen shot
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
roskirko
Perhaps trying several independent componenet "roads" would help. Use one set of components for one of the directions; another for the other direction and perhaps a third for the median.
Geographic Information Systems
Fanshawe College
Beka_Tchigladze
@roskirko
thank for your replay.
yes maybe but donot forget that I have 3 road in this case if I split directions and I need same vertical profiles how to match vertical profiles if I split?
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
Hi @Beka_Tchigladze ,
Actually, you should have four roads: two intersecting and two ramps. For every ramp, you should play with lane components as you can see on the screen shots. Sleep road lane should have right direction.
Goran
Beka_Tchigladze
it does not work with same way in my case
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
