- Mute
- Permalink
- Report
I have imported a 3d model from Civil 3d into IW which uses materials like a metal mesh. At first, it is coming up correct, see the picture, but when reopening the IW, model will not open and gives an error. After checking the log file, it is clear that it is the path name length which is causing the issue (attached). Having the problem identified, still I am not able to solve this issue, because when changing the path name in the model folder or shortening the material name in Civil3d, IW will not show materials at all for this 3d model. Thanks for help!
