Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Cannot use Model Builder though already subscribed
Hi. It worked the first time when I had a trial. Now I have a student licence but I cannot use it. Screen Shot 2018-05-16 at 7.33.00 pm.png
Replies (7)
SethHall
Hi @Anonymous
Did this just start happening, or has this always behaved this way?
Can you try to create a new model from the "new" button on InfraWorks home screen, and select collaborate? Can you create a model to a Group (18.2 and earlier releases) or BIM360 Folder (19.0 release). What happens when you do that?
I would also try signing out of InfraWorks and signing back in and see if that helps.
Seth Hall
Product Owner
Model Builder
SethHall
I missed the part where you said you had a Trial and now a Student license. Did you sign up under different email addresses? Are you using the same user name?
Seth Hall
Product Owner
Model Builder
I created a new model from the "new" button and it showed this.
I tried signing out and then signing in but it didn't work. I think the Trial and Student license are under the same account.
SethHall
@Anonymous
Thanks for that! What happens when you click on the "web administrator" and try to manage the model? If you could provide the link via private message, it should have a model ID in the URL.
Thanks!
Seth Hall
Product Owner
Model Builder
I clicked on the "web administrator" and it showed this. Screen Shot 2018-05-17 at 12.06.47 pm.png
The link is https://infraworks360.autodesk.com/portal/admin/modelId/427737/
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous
the explanation for the 404 - not found message on the web page is found here:
http://knowledge.autodesk.com/article/InfraWorks-cloud-service-and-web-page-is-not-available
Karsten
Karsten Saenger
SethHall
@Anonymous
Thank you, that is very helpful. I have forwarded that off to the appropriate team and they will be looking into it shortly. I will post back here when I have more information.
Seth Hall
Product Owner
Model Builder
