Is there a way to fade an aerial image in InfraWorks the same way you do in Civil3D? I created some snap shots of a few proposals in Infraworks for a meeting and the comment that kept coming back was to fade the aerial so the proposed roads stand out more. Any ideas or do I need to post this as an idea? The engineering view is a good fade, but it makes everything transparent.
Solved by ocastaneda. Go to Solution.
You can control the Surface Opacity, which is what you are seeing in Engineering View, but you can edit it further than the default settings: http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-7EA8F78C-CCDE-47C9-8D62-61B1DE5AA609
you can change and configure a workspace and make it stand out and transparency
Hi @DaneMartin
There are a couple of ways to accomplish this within Infraworks, that I have found working on this. Here is a screencast where I share what I do when in need to make my aerial images clearer:
I hope this helps bud!!!
If you find this answer helpful please click the ACCEPT solution and/or if you like my answer please click on the KUDOS button...
Oscar Castaneda
Transportation Designer / P.E.
Infraworks Ambassador
Thanks, Oscar. The gradient trick and adjusting the view setting will get me the look I need for the snap shots. Thanks for taking the time to create a Screencast.
Dane
