InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Can't import DWG containing 3D objects
4 ANTWORTEN 4
Nachricht 1 von 5
neilyj666
163 Aufrufe, 4 Antworten
I'm trying to import AutoCAD dwg (3D Objects) but if I have the Navisworks based local import ticked....
.... I can't import my model (yes - I have Navisworks Manage 2025 installed) and get the following error messages which in typical Autodesk fashion are less than helpful.
...but after turning this Local Import off, the model imports as expected.
This is somewhat counterintuitive to me so can anyone shed any light on this behaviour
I also noted that there is no longer a 3D view of the model in the import dialog now - when did this change?
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
4 ANTWORTEN 4
Nachricht 2 von 5
Karsten.Saenger
als Antwort auf: neilyj666
Hi @neilyj666 ,
the missing 3D preview in the data source configuration is a known issue and it's already reported to the development team.
Regarding the local Navisworks import in InfraWorks 2025, I can recreate it as well on my side. I will create a support case for you and report it to the developers as well.
Karsten.
Karsten Saenger
Nachricht 3 von 5
neilyj666
als Antwort auf: Karsten.Saenger
@Karsten.Saenger Thanks for the update
I am also having difficulty bringing in a simple Revit building using the import Revit option and I also tried going Revit > NWC > FBX and import 3D Model in Infraworks and nothing appeared. I tried interactive placing and the fbx appeared briefly but disappeared when i placed it and it was nowhere to be seen.
Can you see if you can reproduce this behaviour too?
Nachricht 4 von 5
Karsten.Saenger
Hi @neilyj666 ,
are all problems with the "local Navisworks import" option?
I have created the support case. Can you upload Revit or FBX sample files to the case, so I can also test and report it to the developers?
Karsten.
Karsten Saenger
Nachricht 5 von 5
neilyj666
@Karsten.Saenger seems to be problems with both Local and Cloud import - I'll try again later today but in the meantime I'll upload the revit and fbx to the Support Case
EDIT: Files uploaded to Support Case
Rail Community
