InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Can specific files/folders for model from previous releases be deleted
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
neilyj666
111 Aufrufe, 2 Antworten
@Karsten.Saenger I have several ongoing projects (of which the below is a example) that have been been upgraded at each annual IW update by making a copy.
I assume that  the .files and .sqlite data can be deleted for the previous versions with no issues i.e. all apart from the 2025 versions?
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
2 ANTWORTEN 2
Nachricht 2 von 3
Karsten.Saenger
als Antwort auf: neilyj666
Hi @neilyj666 ,
if the upgraded models work fine in the new release, you can delete the previous versions.
If you want to keep it as backup or load it in a previous InfraWorks version again, don't delete the old models as models are not backwards compatible.
Karsten.
Karsten Saenger
Nachricht 3 von 3
neilyj666
als Antwort auf: Karsten.Saenger
@Karsten.Saenger thanks - that was what I thought would be the case...:grinsendes_Gesicht:
Rail Community
