Can open C3D files in Infraworks
Message 1 of 9
I have Infraworks 2021, C3D 2021 installed on my machine.  when i try to open Autodesk Civil 3D DWG i get the following error message :
* Unable to find the required Autodesk Civil 3D executable. Validate local installation of Autodesk Civil 3D 2021.
how can I validate the local installation of Autodesk Civil 3D 2021 so infrawork knows it there.  any help would be appreciated
Replies (8)
Message 2 of 9
Todd_Rogers
Are you sure you're using InfraWorks 2021?
Todd Rogers
Civil Administration at Walter P Moore
Message 3 of 9
Todd_Rogers
If the versions of Civil 3D and InfraWorks match but the error message still appears, double check if Civil 3D is installed in an "unusual path" other than C: drive. Installing it on a standard location might solve the problem.
Try the following as an alternative:
  1. Export data from Civil 3D in IMX format. See: To Import and Export IMX Files.
  2. Import that IMX into InfraWorks. See: To import Autodesk IMX data.
Todd Rogers
Message 4 of 9
yes using IW 2021.  have C3D 2021 installed on same machine
Message 5 of 9
have checked installation and all installed in correct locations. I have successfully done the IMX workaround but would like to get the C3D import working too
Message 6 of 9
Todd_Rogers
Can you go to Application Options, under General and then About, and provide a screenshot?
Todd Rogers
Message 7 of 9
screenshot attached
Message 8 of 9
Todd_Rogers
Interesting. Let's see if @Karsten.Saenger has a solution.
Todd Rogers
Message 9 of 9
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
the issue can also be caused by version conflicts of updates.
Please make sure that InfraWorks and Civil 3D are installed with the latest updates or deployment settings with installations.
The knowledge base article for the issue is this:
https://knowledge.autodesk.com/article/Error-message-when-trying-to-open-a-Civil-3D-DWG-in-InfraWorks
In some cases it helped to add a registry key with following commands:
set val="C:\Program Files\Autodesk\AutoCAD 2020\\"
REG ADD "HKLM\SOFTWARE\Autodesk\AutoCAD\R23.1\ACAD-3000\Install" /V INSTALLDIR /T REG_SZ /D %val% /F
Karsten.
Karsten Saenger
