Bridge Intersection
Bridge Intersection
gustavo_bergoya1
Message 1 of 9
Bridge Intersection
gustavo_bergoya1
Hi group,
I want to create a ramp from bridge, but it create a intersection with grading
This is a example:
this is my bridge design that I want to make a ramp:
Replies (8)
Message 2 of 9
jim_geer
Hi @gustavo_bergoya1,
Unfortunately at this time intersections are not supported on bridges.  This is something that is on the roadmap and hopefully will updated in a future release.  I will let you know when I have an update.
Jim Geer
Principal Software Engineer in Test
Message 3 of 9
gustavo_bergoya1
Hi Jim,
In the previous version if I could do it
Message 4 of 9
jim_geer
Yes previously you could get it to look closer.  Although the bridge was not correct under the intersection.  As we toward detailed design we want to make sure we support ramps/intersections on bridges.
Jim Geer
Message 5 of 9
gustavo_bergoya1
Ahhhh ok, you are right,
Thank you very much.
Regards
Message 6 of 9
its
Has autodesk found a solution for this?? I have the latest 2019 Infraworks version.
Message 7 of 9
jim_geer
This is something that we are still going to work on.  We did some work with the 2020 version.  If you have two bridges intersecting you can now delete components easier.  So you can delete and abutment to do some cleanup where two bridges intersect.  If a component needs to be added back there is an option for that in the right click menu.
Jim
Jim Geer
Message 8 of 9
engr_waqarghori
Community Visitor
Community Visitor
I have same issue since last 3 years related to bridge intersection connection, kindly send me the complete video of this..
Message 9 of 9
trusty110
Great!  thanks for this.
I am searching for an example of an Infraworks (or any) project of a traffic intersection with an overpass that has
offramps to a roundabout intersect below.  Please link to my email: trusty110@gmail.com
Thanks again,
Bill
