Hello Everyone,
Just wanted to give you a heads up on another new feature that we introduced for Bridge Design in the 2017.3 release. Bridge Templates!
You can now save your entire bridge configuration (all of the component types, as well as any customization done to them) and reuse it on other bridges, and in other models - in just a few clicks!
Customize a bridge, and with the bridge selected, Right click > Add to Library, give your template a name and click OK. Now select another bridge and at the top of the stack you can see if it is using a template. Click the hyperlink (orange text), select your new template from the catalog, and you are done - all of the components on your bridge will update!
The attached video might explain it a little better.
Let us know what you think!
-Austin Jephson
