Bridge beams - hide
Bridge beams - hide
vaclav_hirsch
Bridge beams - hide
vaclav_hirsch
Hi team,
Is there any option to NOT display, or perhaps delete, bridge beams and deck from a selected bridge span?
In that span, I have placed a generic object, an element representing truss type bridge superstructure. I don't want to have both the generic object and beams with deck in that span.
Illustrative snippet is attached.
Thanks, V.
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @vaclav_hirsch ,
to hide bridge components, you have basically three options.
Either switch them off via the right mouse click menu or switch them off in the Model Explorer or assign 0-values to the properties.
Each option has different effects.
See also:
Karsten.
Karsten Saenger
