Better Quality Models
Hello everyone,
I want to use infraworks for a media project. So I need to do closeup renderings from Berlin for high res use.
The OSM Source is a fine thing, but not good enough. I tried to import citygml from the Stadtsenat, but others tried the same here in the forum and failed like me. So do you know some Tips how or where I can get better quality files?
Thank you and best regards
Tunkali
elliott.rosenfeld
What types of data are we talking about? i.e. which features? Finding data is very dependent on your location, the type of feature (i.e. buildings v. roads v. terrain v. aerial imagery v. point clouds, etc.), and whether you are able to purchase data, or you want to find publicly-available data.
Elliott
Principal Specialist, Infrastructure
Building Data is required. So through OSM I only get low quality LOD2. I could also invest a little bit money if required. So I am looking for good data sources that i can import in Infraworks.
Tunkali
John_DeLeeuw
Hi Tunkali, check out Cybercity3D buildings. I'm not sure if they already have buildings in your area but you can always ask for a quote. These buildings have a high quality and accuracy.
Best regards,
John de Leeuw
Senior Consultant
Community Ambassador - Twitter - LinkedIn
Matt__W
Another possibility might be 3D Warehouse. The models are SKPs which can be imported.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
elliott.rosenfeld
John and Matt's suggestions are good ones. Unfortunateley, I don't have any other ideas for Berlin data at the moment, although you may want to give the OSM CityGML data another try. It looks like that portal for Berlin LOD2 data allows for other formats than CityGML, which may make things easier.
Best,
Elliott
Ok, thank you. So there is no good source for overall buildings. So it seems I have to collect from local dealers and services. Maybe there is more in future :). Or develope an offline importer for citygml! 🙂
