Adding data sources to project with javascript
I have a *.sqlite base that was created in Infraworks sometime before and a I need to load some sources from it to the new project using javascript
While looking through some tips and js samples, I found one of the way to load data. As far as I undesrstood it uses providers method.
Here is a code where I want ro add BUILDINGS_NEW to the data source list:
var wkt = app.ActiveModel.CoordSysWkt;
file = "D:/Projects/MyModel.sqlite"
var sd = fdo.OpenDb(file)
print (sd.TableCount);
var providers = app.GetDataProviders(".sqlite");
for (i=0; i<sd.TableCount; i++) {
    if (sd.Table(i).Name == 'USER_BUILDINGS_NEW'){
        print ('        your table has been found');
        var tb_f = sd.Table(i)
        path_t = file + '/' + sd.Table(i).Name;
        for (p in providers) {
            var configs = providers[p].FileConnect(md, path_t);
            for (c in configs) {
                print (c);
                for (mm in c){
                    print (mm);
                var cfg = configs[c];
                cfg.TargetClassName = 'BUILDINGS';
                cfg.SourceCoordSys = "XY-M";
                cfg.PosCoordSys = wkt;
                cfg.Name = 'USER_BUILDINGS_NEW';
                cfg.Description = 'DEAF';
                cfg.AnchorType = adsk.Enums.LocalOrigin;
                // cfg.Position = point.BBox3d.Center;
                cfg.Is3D = false;
                var result = cfg.Import();
                if (result) {
                    print("INFO: 3d model imported for " + 'USER_BUILDINGS_NEW' + "; bbox = " + result.AffectedExtent.ToString());}
                else {
                    print("ERROR: 3d model import for " + 'USER_BUILDINGS_NEW' + " failed: " + path_t);
                    success = false;
Here I've got nothing.
What can be wrong or is there a completely another way to add new data?
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous
do you know the Java Script API documentation of InfraWorks?
It's attached in the following knowledge base article:
http://knowledge.autodesk.com/article/Autodesk-InfraWorks-JavaScript-API-Documentation
Start searching for "SaveActiveCityAsJson" and "CreateCityFromJson" or "ImportDataSourcesIntoActiveModel" or "ImportDataSourcesIntoActiveModel"...
Karsten
Karsten Saenger
Yes, already found and tested it. However *.dwg models do not load properly, Infraworks says that datasource is missing but json file contains all needed data for import.
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous
the explanation is probably that the API is from 2014 and was not developed/updated since then.
The Civil 3D DWG import - and other functions - were added later to InfarWorks, so the API doesn't "know" about those.
Karsten.
Karsten Saenger
