InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
360 Camera View
12 REPLIES 12
Message 1 of 13
jaronkDDX26
971 Views, 12 Replies
360 Camera View
I wanted to take some images from several viewpoints of my infraworks model. There are about 22 spots where I want to take several photos all from a single human POV. Is there a way to rotate the camera or a way to navigate with the camera to produce these photos? For what I know the camera rotation is always focused on just the middle of the screen and the scrolling of the camera is way too fast to quickly set up the photos
12 REPLIES 12
Message 2 of 13
andrewofabley
in reply to: jaronkDDX26
@jaronkDDX26
So to be clear, you want to create 360 degree panoramas at 22 set locations?
AEC Collection / Safe FME / ESRI ArcGIS / Unreal Engine
Digital Engineering Lead, Compulsive Problem Solver.
Message 3 of 13
jaronkDDX26
in reply to: andrewofabley
Yes that's correct but I'm aware there's no panorama feature so I was wondering if there's just an easier way to navigate the camera and take screenshots to mimic the effect
Message 4 of 13
andrewofabley
There was an easy way of doing panos via the web model. Do you want something more sophisticated?
The camera can be controlled by an external JSON file in the storyboard.
In theory, setting field of view to 90 degrees (or 120), then rotating the camera direction 4x or 3x would do it.
You coul render that to a video file, and then scrubbing the time slider would rotate your Pano - otherwise you could capture statistic images and join em after.
With JSON you could automate this for each location.
I've certainly used this method when I had to place the camera precisely.
Message 5 of 13
@jaronkDDX26 I am sure you can have script to move the camera to desired location and elevation, I also have script to batch generate screen shots from bookmarks. Will those work?
Ramesh S
Product Manager - Infrastructure Solutions
Ramesh.Sridharan@autodesk.com
Ramesh Sridharan
Product Manager
Message 6 of 13
That is a useful script to have as well! If you don't mind sharing I would love to use it
Message 7 of 13
Here you go. As always, please use the scripts carefully and take back up of your model, if needed./
Batch Snapshot Script:
https://myshare.autodesk.com/:u:/g/personal/ramesh_sridharan_autodesk_com/EZ2u5jpq5ktIrI-3tI9jHU4Bxj...
https://myshare.autodesk.com/:u:/g/personal/ramesh_sridharan_autodesk_com/EeQzphh6eUZKqTUwnA9hmKABsd...
Move to Elevation Script:
https://myshare.autodesk.com/:u:/g/personal/ramesh_sridharan_autodesk_com/EQwYEDGTX7tIgBddQFx35doBWL...
https://myshare.autodesk.com/:u:/g/personal/ramesh_sridharan_autodesk_com/Ebri8qqi53VDvkXkjFYbv2QBiv...
Ramesh S
Ramesh Sridharan
Product Manager
Message 8 of 13
Hi Ramesh, Can you repost links above for Batch Scripts ? I tried to access but it looks like they might have expired.
Shane Hollander
Message 9 of 13
@shollander2KBE7, Please email me (ramesh.sridharan@autodesk.com) and I will send it as attachments. Thanks,
Ramesh S
Ramesh Sridharan
Product Manager
Message 10 of 13
HiRamesh, will you mind share the scripts with me as well? Thank you
Message 11 of 13
I tried stitching screenshots from infraworks to panoramas but it was lots of work.
It was easier to take the model to twinmotion, it has built in panorama export.
Message 12 of 13
tony1978
In the storyboard, you can do a 360 degree video rotation view. Is that what you are looking for?
In the storyboard, you can use the Add Look Around feature.
If you want just simple render snapshots then like everyone else pointed out you can create bookmarks.
 Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
Message 13 of 13
lim.wendy
Hi Jaron,
Thanks for reaching out to the forum. Have you had a chance to look over Tony's suggestions?
Please let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Rail Community
