You can now save your entire bridge configuration as a template, and apply it to any other bridge in just a few clicks! This will swap out all of the components, as well as any customization that you have done on your bridge.
Just customize a bridge, and with the bridge selected, Right click > Add to Library. Give your template a name and click OK. Now select another bridge and at the top of the stack you can see if it is using a template. Click the hyperlink, select your new template from the catalog, and you are done - all of the components on your bridge will update!
Check out the attached video to see it in action!
Explain how one would then copy/import this Bridge Template we just made into a new IW model.
Not just apply it to other bridges in the same model?
Hi, @KPerison. I think this article may have the solution to what you asked 🙂
Link: https://www.solidcad.ca/infraworks-custom-assemblies/.
