You can now toggle on/off the visibility of your various bridge components. Here is how you do it...
Hit the 'T' key to toggle on/off the Component Display Toggle, or use the check box in the Right Click menu.
Right Click and you'll see the main checkbox with an expandable list. Open that up and check or uncheck the various components that you want to be toggled via the Component Display Toggle.
Note that the selected object will always remain visible. At the end of the video you can see how I select a single girder, then hide the rest of the girders using the toggle. Click again on the girder to select the girder group, making the girder group visible.
As always, let us know what you think!
-Austin
Greetings, thank you very much for the contribution, I will put it into practice ...
Atte.
ESPAÑOL
Saludos, muchas gracias por el aporte, lo pondré en practica...
Atte.
PD:
Si la info es de tu interés, dale manitos arriba (KUDO)...
Si la info da solución a tu inquietud, o es conocimiento nuevo para poderlo aplicar en el futuro, acéptalo como SOLUCIÓN...
TU ACEPTACIÓN O APOYO EN CUALQUIERA DE LAS 2 FORMAS, ES EL INCENTIVO PARA PODER SEGUIR APORTANDO CON LO MUCHO O POCO QUE SEPAMOS DE ESTE GRAN SOFTWARE PARA EL BIEN DE TODA LA COMUNIDAD...
Felices festividades de Carnaval y feriado...
ALEJANDRO PANCHANA (Guayaquil-Ecuador)
Facebook | Twitter | Screencast
When you click off (deselect) the bridge, the transparency goes away. Is there a way to allow it to remain? It used to do that with the toggle transparency command.
