InfraWorks 360 Forum
Welcome to Autodesk’s InfraWorks 360 Forums. Share your knowledge, ask questions, and explore popular InfraWorks 360 topics.
Highlighted
Post 1 of 4
Water style
55 Views, 3 Replies
03-08-2017 02:26 PM
It's there a way to change the animated water styles to a different color. We only have dirty ditches in our country instead of Carribean Blue :-)
Unfortunately, it is not currently supported to change the color of the water style while preserving the realistic water animations. This is due to the fact that the animated water style shader is built on a highly complex mathematical formula that must take into account the physics/reflections of the sky background, and we haven't yet put the resources towards adding other colors with realistic water shading -- although it is something we would like to get to.
If you want to simply change the color of a water style, for instance, muddy brown water, or tropical blue-green water, you can apply a different color to a water style. The only caveat is that you not be able to apply realistic water animations to that style. You can do this via the Style Palette, in the Water tab. Copy one of the existing water styles, and assign a new color to that style, then apply it to your water feature. Let me know how this goes.
Elliott
Re: Water style
03-08-2017 03:01 PM in reply to: zottt
Elliott
Sr. Learning Content Developer
Autodesk PDG - BIM - InfraWorks 360
Post 3 of 4
Re: Water style
03-08-2017 11:33 PM in reply to: elliott.rosenfeld
Thanks for the response!
I'll use this workaround for now, but am curious of new adaptions :-)
Post 4 of 4
Re: Water style
03-09-2017 12:18 AM in reply to: zottt
@zottt and @elliott.rosenfeld, you can both vote here to get this functionality implemented sooner!
We really need this in the Netherlands Smiley Wink
John de Leeuw
Senior Consultant
Community Ambassador - Twitter - LinkedIn
