Simple question,
How do I update to the latest version of Infraworks (17.2)?
Solved by Eduardo.Soethe. Go to Solution.
Hello @jamesmac1200!
You can download the latest version from here:
http://www.autodesk.com/products/infraworks-360/free-trial
Just sign in and you will see the latest version. Or you may use Autodesk Download Manager, which will give you the latest software overall.
At your disposal for further clarification
Nicola
I don't see any available updates for Infraworks, I thought Autodesk was going to release 17.2 today maybe check back later today or tomorrow.
It's available on your subscription page!
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
InfraWorks 360 2017.2 is the September 2016 release of InfraWorks 360. Our product team is currently working to release the 2017.3 release version (January 2017 release) of InfraWorks 360, most likely within the next few business days, tomorrow if we're lucky. stay tuned.
Here are the links to the different versions:
Elliot Rosenfeld posted them in http://autodesk.typepad.com/bimagination/2016/04/download-and-use-infraworks-360-in-presenter-mode-f...
My apologies everyone I meant the 2017.3 update keep an eye on Subscription Center...
This gets right back to the question I asked HERE, what version am I downloading? There are now three completely different versions of InfraWorks 360 all called "2017" but there is only one option for download. What if I need 2017.1 because that's the version my project is on? There's no option to download 2017.1, just 2017.
Hi @BrianHailey,
you can add it to the Idea Station. I think that, as @elliott.rosenfeld said, oyu will always be downloading the latest official release of the app.
Up to now it is 2017.2, soon it will be 2017.3
Or you can use the direct links provided above.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Which is the crux of my problem. The new version was supposed to be release recently. Was it? In the past, Autodesk has delayed releasing software for various reasons and now, when I look at the download, how do I know which one I'm downloading? I can't.
The idea station, from what I understand, is for the software developers. They do a great job in creating the new versions. What this needs to go to is the web developers. Don't think the idea station would get there (although I could be wrong).
Hi @BrianHailey,
well if you want to modify anything on the software, or want anything modified, you have to go through there.
It is a good place to discuss and show what you have in mind. @elliott.rosenfeld what do you think of that?
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Hi Elliot,
Is it possible to update the links to the older versions? The old ones wont work anymore.
Thanks!
I can uninstall the software and download the trial of the page, that already came updated.
