InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Tilting objects on a 3D Line
9 REPLIES 9
Message 1 of 10
zottt
806 Views, 9 Replies
How can I tilt objects (city furniture) along a 3D Line (Exported from civil via sdf). So for instance a guardrail will follow my 3D Line instead of putting horizontal objects after each other.
9 REPLIES 9
Message 2 of 10
elliott.rosenfeld
in reply to: zottt
To apply tilting, you will need to use the City Furniture as a road decoration. Once the decoration has been added to the road, the Stack will show a Tilting option. This happens two different ways:
For Design Roads, add the decoration to the road style and then apply tilting: https://forums.autodesk.com/t5/infraworks-360-infratips/road-decorations-use-tilting-to-follow-the-v...
For a component road, simply Place a Decoration (http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-2EEB449C-18F4-4342-AC91-BFC57A721141), then with the decoration selected, turn on Tilting in the Stack.
Note that vertical decorations such as lamp posts will not apply tilting.
Elliott
Principal Specialist, Infrastructure
Message 3 of 10
elliott.rosenfeld
in reply to: zottt
One other great option if you .SDF guardrail profiles, is to add them to a design road style as custom profiles, which will follow the road alignment without tesselation, You can read how to do that here: http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-D22FACFA-529C-4C8A-9CB5-5A91AF0BEB3F
Message 4 of 10
zottt
in reply to: zottt
I tried that, but the problem then is that it may interfere with roads I have in my model..
Message 5 of 10
elliott.rosenfeld
in reply to: zottt
Hmm. I wonder if creating a null road style that doesn't have anything in it but a decoration would do the trick. Would you be able to share a screenshot of your use case?
Elliott
Message 6 of 10
zottt
in reply to: elliott.rosenfeld
Hi Elliott,
Thanks for you reply! I used it as a road style and it works.
There are some issues:
-how do you deal with guardrails on bridges (create a new style)
-at the start/end of a guardrail, I want te let it dissapear in the ground, when using a roadstyle it'll change my groundsurface
-a guardrail is technicly not a road, so it should be shown as a city furniture
Message 7 of 10
elliott.rosenfeld
in reply to: zottt
Hey Zottt,
Glad you got it working!
As to your questions:
For design roads, the bridge exists underneath the road, and is assigned a road style. Therefore, you can use a road style that has been stylized as a bridge, such as Street/Bridge Deck/Simple Barrier (pictured below). If you want, simply change the road style to reflect the decorations you want to use.
For component roads, you can place a guardrail decoration, adjust spacing (I use 3m instead of 10m), and turn on tilting.
I dont think we currently support this type of workflow, but it is a good idea. I would consider adding this to the idea station.
Agreed. In InfraWorks we consider road decorations to be additions to a road. But you've got a good point there. Where are you seeing it 'shown' as city furniture?
Thanks!
Elliott
Message 8 of 10
This issue came up just last week where a fence from a two-tone (black and white) image was created as a barrier. I knew that the tilting was available as you have described but that option would be nice to have for the barriers as well where the fence element was placed. Perhaps I should place this thought into the ideas section.
Geographic Information Systems
Fanshawe College
Message 9 of 10
zottt
in reply to: roskirko
When the tilting can be done in Barrier styles, this would be the best solution!
Message 10 of 10
roskirko
in reply to: zottt
I managed to take a raster (attached) which is bi-tonal (the background is "transparent") and extract polygons / polylines from it using PCI Geomatica (I do not know yet if AutoCAD Raster Design can do this but I have asked that question in that forum).
From there, the data extracted  (in the DXF format)  is converted to AutoCAD regions, has constructive solid geometry tools applied (Subtract) and then a 3DSolid is created after the Extrude command is used in AutoCAD. From there, an FBXExport with materials (Black Paint) is then brought into Infraworks as a 3DModel from the FBX file. The 3D Model is then applied as a decoration of a Component road (the decoration can then be "tilted" with the land surface). The road lane in the example below has to be replaced with a transparent material which I can do for a Design Road but as of yet, not for a Component Road.  Anybody know how to add materials / elements to the Component / Assembly folder?
Fanshawe College
Rail Community
