So I have a bathymetric survey in my model. I also have a water area.
When I show the water area the bridge foundations uses this as it datum. If I turn off the water area the foundations use the bathymetric survey.
Is there a way to have the water area on and for the foundations to use the bathymetric survey as the datun, and NOT the water as the datum?
Solved by Matt__W. Go to Solution.
It's been a little over a month since you posted so maybe you've found a solution but.... Here's what I was able to come up. I simply copied the default water style and toggled off the INTEGRATE WITH TERRAIN option.
NOTE: I exaggerated the water level simply for demonstration purposes.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
