Hi everyone
I have two principal roads that they depart separate and then they arrive united on a bridge.
This bridge has two principals piers and is suspended. How i can to model the two separate roads and join them together in a single street?
how I can change the deck of a bridge? I want to switch between two separate decks to a single deck
thank you all
and sorry for my english
Michele
I must admit that I have never attempted this use case before. However, I think you can accomplish this by drawing one road that crosses your water body (and therefore is automatically created as a bridge), then drawing another road that intersects in the middle of the water body. This is what I came up with:
When looking underneath at the girders, this is definitely not a perfect solution. I'll ask the bridge team if they have any additional advice.
Elliott
Hi @m.deviato
Unfortunately at this time there is not a way to combine two bridge decks into one. As Elliott showed you can combine the roads into an intersection above the bridge. However at this time bridge intersections are not supported.
Hi @jim_geer @elliott.rosenfeld
Thanks for the info.
For for a better understanding i attached here a photo about this situation.
if can not do with IW360 can i do whit C3D bridge modeler and then insert into Infra?
Thanks for all
Michele
Hi @m.deviato,
I would rather use Revit, maybe with the Civil Structures extension, for that intersection.
This is the best way to get the correct dimension. And then you can also retrieve quantities etc.
Best
Nicola
has any other development been completed on this. seems to still be an issue almost a year later...
