So I've created a bespoke pre-cast girder by creating a unique section along it's length, what I would also like to do is change it's material but cannot see a way of doing this.
Does anybody know of a way of achieving this or am I stuck with the 'out of the box' concrete?
Hi TrevN,
Which version of Infraworks are you using? In Infraworks version 2017.2 you can select a girder and change the material texture of the girder. Unfortunately in earlier versions you can not do this.
That's what I thought. I am running 17.2 but that option isn't popping up, I've check all the attribute options to make sure nothing is turned off.
Must be missing something somewhere, hmmmm......
I'm sorry I got my releases wrong. The girder material was added for 2017.3. In 2017.2 you can set the material texture for piers, foundations & abutments.
It actually hasn't been released yet. It will be getting released soon.
