InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
No Imagery displayed
13 REPLIES 13
Message 1 of 14
antoniojcarmona
730 Views, 13 Replies
Good morning,
I´ve browsed through the forum seeking for an answer for my problem and I´ve tried every proposed solution (Set a new GLDATA, import a new Bing Map Imagery...) but it seems none of them works for me.
I´m using the model builder in IW 17.2.314.0.
The imagery of every model is set in configured, but when I try to refresh the model the following message appears
We need the imagery in order to perform several projects, so any help will be much welcomed.
Thanks!
Aeronautical Engineer/Airport Engineer at Ineco
13 REPLIES 13
Message 2 of 14
Matt__W
in reply to: antoniojcarmona
Hi @antoniojcarmona first, make sure your internet isn't blocking any of the sites listed in this AKN article.
Also, check this forum posting for some additional possible solutions.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 3 of 14
From looking at your log file, it seems that your EPSG code for GDAL WMS data connection isn't correct. Are you using the built-in Bing Maps database connection to load in the imagery?
Elliott
Principal Specialist, Infrastructure
Message 4 of 14
hi @elliott.rosenfeld @antoniojcarmona @Matt__W
I have the same problem about imagery displayed.
Michele
Message 5 of 14
antoniojcarmona
in reply to: Matt__W
I´ve talked to the IT Department and they said there´s no proxy neither any of the remarked websites are blocked.
I´ve tried every solution shown in that thread but it seems it doesn´t work. This problem starts to be annoying 😞
Thanks anyway @Matt__W
Message 6 of 14
good morning @elliott.rosenfeld ,
I´m not sure what do you mean by using built-in Bing Maps database, I always use the Model Builder to determine locations. Every time no Imagery is displayed, I try to add a new one by clicking on add data source, I select Bing Maps as shown in the pic below
Antonio
Message 7 of 14
SethHall
in reply to: m.deviato
@m.deviato are you using 2017.2 as well? If not, please let me know what version you are using.
Seth Hall
Product Owner
Model Builder
Message 8 of 14
m.deviato
in reply to: SethHall
hi @SethHall
I had a problem with proxy server. Now all ok.
@antoniojcarmona i had the same problem. I talked with IT service for the server list (https://knowledge.autodesk.com/support/infraworks-360/troubleshooting/caas/sfdcarticles/sfdcarticles... must have all necessary permits unlocked for downloading ground images.
Michele
Message 9 of 14
SethHall
@m.deviato Glad to hear it!
@antoniojcarmona I just installed a fresh build of 2017.2, created a model and the imagery came through as expected. Does this happen on other machines that you log in to?
Seth Hall
Product Owner
Model Builder
Message 10 of 14
antoniojcarmona
Thanks @SethHall I´m still not sure about what´s happening.
I´ve also tried from Civil3d 2015 to import bing maps, but then a message is displayed telling me that I have no permission to access to online topography
Message 11 of 14
SethHall
Does it matter the location selected for your model?
Also, does this happen when you log in to another computer to see if this occurs?
Seth Hall
Product Owner
Model Builder
Message 12 of 14
antoniojcarmona
Hi @SethHall it is important because I had to plan if it´s necessary to expropriate terrains outside an airport area to perform several ICAO rules.
I can not try InfraWroks in other computer, it is only installed here in the office 😞
I´ve updated to IW 3.0 but the problem remains.
Antonio
Message 13 of 14
SethHall
@antoniojcarmona I am still looking into this... I'll try to get you some suggestions shortly.
Seth Hall
Product Owner
Model Builder
Message 14 of 14
antoniojcarmona
Thank you very much @SethHall
I have made some progress with IW: I´ve been able to work with surfaces and georeferred images but not using the model generator but from Civil 3D Data.
Anyway I have to add manually the coordinates, I mean, I have to set manually the coordinate system (WGS84) and the UTM Zone,
Rail Community
