Good morning,
I´ve browsed through the forum seeking for an answer for my problem and I´ve tried every proposed solution (Set a new GLDATA, import a new Bing Map Imagery...) but it seems none of them works for me.
I´m using the model builder in IW 17.2.314.0.
The imagery of every model is set in configured, but when I try to refresh the model the following message appears
We need the imagery in order to perform several projects, so any help will be much welcomed.
Thanks!
Hi @antoniojcarmona first, make sure your internet isn't blocking any of the sites listed in this AKN article.
Also, check this forum posting for some additional possible solutions.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
From looking at your log file, it seems that your EPSG code for GDAL WMS data connection isn't correct. Are you using the built-in Bing Maps database connection to load in the imagery?
Elliott
hi @elliott.rosenfeld @antoniojcarmona @Matt__W
I have the same problem about imagery displayed.
Michele
I´ve talked to the IT Department and they said there´s no proxy neither any of the remarked websites are blocked.
I´ve tried every solution shown in that thread but it seems it doesn´t work. This problem starts to be annoying 😞
Thanks anyway @Matt__W
good morning @elliott.rosenfeld ,
I´m not sure what do you mean by using built-in Bing Maps database, I always use the Model Builder to determine locations. Every time no Imagery is displayed, I try to add a new one by clicking on add data source, I select Bing Maps as shown in the pic below
Antonio
@m.deviato are you using 2017.2 as well? If not, please let me know what version you are using.
hi @SethHall
I had a problem with proxy server. Now all ok.
@antoniojcarmona i had the same problem. I talked with IT service for the server list (https://knowledge.autodesk.com/support/infraworks-360/troubleshooting/caas/sfdcarticles/sfdcarticles... must have all necessary permits unlocked for downloading ground images.
Michele
@m.deviato Glad to hear it!
@antoniojcarmona I just installed a fresh build of 2017.2, created a model and the imagery came through as expected. Does this happen on other machines that you log in to?
Does it matter the location selected for your model?
Also, does this happen when you log in to another computer to see if this occurs?
Hi @SethHall it is important because I had to plan if it´s necessary to expropriate terrains outside an airport area to perform several ICAO rules.
I can not try InfraWroks in other computer, it is only installed here in the office 😞
I´ve updated to IW 3.0 but the problem remains.
Antonio
@antoniojcarmona I am still looking into this... I'll try to get you some suggestions shortly.
Thank you very much @SethHall
I have made some progress with IW: I´ve been able to work with surfaces and georeferred images but not using the model generator but from Civil 3D Data.
Anyway I have to add manually the coordinates, I mean, I have to set manually the coordinate system (WGS84) and the UTM Zone,
