Was using 123D catch to make make models from photos but Autodesk advised me to use Remake instead. So after loading Remake last month I made a couple of test models. Now I returned from Europe with new photos to create new models but when I click on Remake it won't work unless I choose to download Infraworks 360 which I did and it's a totally different looking application and not sure how it works. I don't see where I can load my pictures to create a model from photos or if it even performs that function. I would really appreciate some help, thanks.
Best regards,
Blair
InfraWorks isn't the application to use to create a model from photos - ReMake is, as you already know. InfraWorks is for preliminary civil/site design.
After you installed InfraWorks did you try ReMake again?? You might get a better response if you post in the ReMake forums.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Hi @meichnerb
other than ReMake you can also process a 3D model from photos with Recap 360: https://recap360.autodesk.com/
I haven't heard of Remake demanding for InfraWorks yet as you state "Remake - it won't work unless I choose to download Infraworks 360".
Karsten.
please follow up the ReMake forum case:
Cheers,
Karsten.
Hi Blair,
Just want to confirm a couple things.
1) Did you already have Infraworks installed on your machine when it prompted you to get Infraworks?
2) Did it prompt you to get Infraworks in another Autodesk app other than ReMake?
Thanks.
-Karthik
Hi Karthic,
No, Infraworks was not already installed, and no, it doesn't prompt me any where else ( 123D Catch).
It's an upgrade prompt (may say Remake upgrade) that shows on Remake when trying to launch Remake. "Yes" sends you to Infraworks, "no" drops the Remake box, and you can't click on "create a model" in the Remake box, nothing responds in the Remake box. So you have to click on the upgrade prompt and the only choice is to Click "yes" to the upgrade, which you think you're getting a Remake upgrade, but it goes to Infraworks.
Blair
