InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Infraworks: Wire Mesh Material import issue
3 REPLIES 3
NDM_USER
660 Views, 3 Replies
I am importing an FBX model to  Infraworks. The model was done in Revit . The mesh material applied to the wall   doesn't show the cutout . In Revit the rendering looks good
3 REPLIES 3
Nicola_Ianeselli
in reply to: NDM_USER
Hi @NDM_USER,
can you explain a little bit more?
Maybe it is only me but it is difficult to understand what's in the image..
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
NDM_USER
in reply to: Nicola_Ianeselli
In the picture you see a wall exported from Revit to IW via FBX. A mesh material is applied to the wall . The material was applied in Revit . In Revit after the rendering   the wall looks like a wire mesh ,it's a see-through.
Nicola_Ianeselli
Hi @NDM_USER,
oh ok, now I see.
No you cannot do anything related to alpha channel in Infraworks with textures. There is no transparency for material coming from the outside.
There is the need to wait.
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Rail Community
